problem with 3rd
problem with 3rd
ok guys this lil problem has been goin on for a couple months, and is strarting to annoy me. when im in 3rd decelarating, it throws it into nuetral. no other tranny problems so far. so im not sure where to start
well let me know guys thanks
Re: problem with 3rd
I believe the two most common problems with these transmissions are bad syncro's and bent shift forks.
Usually this problem is caused by the syncro. not being fully ingaged. Which would indicate a bent shift fork.
P.S. If you have an aftermarket shifter, make sure the stops are adjusted correctly.
stars1010
07-15-2002 03:51 AM
