rear axle width
Re: rear axle width
Strange Engineering shows (at least in the old catalog cut that I saved when I bought my 12-bolt) the dimension, between the hub flange outer surfaces as 64.72". That is their direct replacement rear axle assembly for a 4th Gen. My 12-bolt was identical to the stock 10-bolt width.
Re: rear axle width
i just measured my 95 and the width from the wheel mating surface with the rotors on is 65 1/8 . i have a strange 12 bolt but when i got it i measured it against my stock 342 posi and it was the same.
FirstGenZq8
09-02-2016 11:05 PM
FLIELOW
02-17-2016 03:46 PM
FLIELOW
02-16-2016 08:33 PM
MRhamlin
01-31-2016 06:12 PM
