Is this rear end strong enough?
I have a link on a 8 ½” rear end from a 69 Z28 that has an auburn posi unit , strange axles, and 4:11 richmond gears. Is this rear end going to hold 500RWHP and slicks, or is this just a slight upgrade over the stock rear in terms of strength? I was also told that this rear end can be switched over to a disk brake set up for pretty cheap. Is that true, as I would like to swap my disk brakes on to it. Thanks for all the responses in advance.
Re: Is this rear end strong enough?
It would probably be strong enough if you could make it work. First problem though, what are you going to do for a torque arm mount? I dont think a 1st gen rear is the same width as a 4th gen, pretty sure it is narrower. No ABS/TCs....
The guy who has it, says he will do the install... He also told me that he put one identical to this, on a 3rd gen Z28... I have no clue when it comes to rear ends, and I am not sure if it can work.. Anyone else have any opinions if it will work.... I don't want the guy to hack my car up to make it work, or jerry rig up something so it can work....
The 8.5" 10 bolt is a pretty stout piece. I had a friend running 10 second quarters in his Chevelle making 650fwhp on Hoosiers with no problems. Making it fit into a fourth gen is another story. I'm sure a competent fabricator can fab up a TA mount and appropriate spring mounts. You've gotta also check the width. I would definitely like to see the 3rd gen car he did first...You'll know right away if its a hack job or not...Good luck...
--Alan
--Alan
10-31-2016 11:09 AM
