Shim 10 bolt carrier very hard???
Old 03-02-2010 | 10:12 PM
fastlt1camaro's Avatar
Is it really hard to shim a 10 bolt carrier correctly? Its out of a 94 z28 thanks.
Old 03-03-2010 | 07:13 AM
AL SS590 M6's Avatar
Moderator
Shimming the carrier is easy. You just move shims from side to side 'till the lash is right after you've got the preload right.
Shimming the pinion to get the gear pattern right is the hard part and the reason that I have a pro do my gears.
So if you are just changing the carrier and using the same gears without moving the pinion, go for it.
Victor Lamb
08-26-2017 02:52 PM
HectorM52
07-30-2017 11:46 AM
maybe2fast
03-16-2015 09:45 AM
HectorM52
Parts Wanted
01-10-2015 09:01 PM
thenewkid
11-18-2014 12:57 PM
Quick Reply: Shim 10 bolt carrier very hard???
