Slave cylinder problem PLEASE HELP
i keep breaking slave cylinders and i can NOT find out what is doing it i have replaced everything but no change anyone had this problem??? they break the inner tube at the base for some unknown reason.....
thanks
im new to this setup also.. thank you for your input just cant find out what would break one slave cylinder right after another. replaced the clutch, flywheel, slave and master cylinder but still broke..
