Strange S60 ABS Question
Old 02-06-2010 | 09:41 PM
Black 97 SS's Avatar
Hey guys did a search and didnt find much help. Im in the process of purchasing a slighty used strange s60 with no ABS. What would be required in adding the ABS to it? Abs Sensor, Reluctor ring bolted to the ring gear and than re-shimmed for backlash? Thanks for the input.
Old 02-06-2010 | 10:48 PM
On my Strange 12-bolt with HD Eaton posi, the reluctor gear is machined into the carrier. It either has it or is doesn't - you can't add one. Might want to check with Strange to see what they do on the S60.
Old 02-07-2010 | 08:56 AM
Thanks, that might be good news if it machined on...That might be standard practice for all there posi units. Hopefully, Ill let you know, Thanks again
Old 02-07-2010 | 10:03 AM
It is not their "standard practice". You only get it if you order it. The reason mine is sitting on a work bench, is because I ordered ABS, but Strange "forgot" to install the posi with the ABS reluctor machined into it. They installed a posi without the reluctor. It took about a month for them to produce the new posi, and ship it to a local shop, where it was swapped out with the incorrect part for free, and the shop's work was included in the Strange warranty.
I wouldn't worry about ABS. Mine worked for about a year, and the Strange sensor (not the same as the factory sensor - and very difficult to adjust) started acting up, and I just disconnected it. Car pulls down from 130MPH traps with no problem.
Old 02-07-2010 | 12:10 PM
I probally wont install ABS, especially if its too costly. It is nice to have in the rain but the car only gets stuck in the rain a few times a year. Thanks for the help
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
jj_burchiel
03-21-2015 12:51 AM
dluna333
15
03-13-2015 12:30 PM
squarehead
01-15-2015 07:02 PM
Quick Reply: Strange S60 ABS Question
