what gears to use
what gears to use
i have 3.42 now,, what should i go to? adding catback, thermo, air foil, tb bypass, hypertech prog, msd coil, plugs, 8mm wires, need some help guys,, 3.73, 3.90 , 4.10. with lockers, help????????????????
Re: what gears to use
I have 3.73s and that is the max I would go with a daily driver. If you are
willing to compromise and will do enough 1/4 mile stuff to make it worth
while then 4.10s. Definately nothing more than 4.10s.
If its an M6... then i say 4.10+. I dont understand why everyone with an M6 is scared to go high on the gears. The M6 with a 4.10 gear still gets better gas mileage than an A4 with 3.23 gears.
You do run the risk of breaking easier with 4.10 than with a 3.73. So if i were you, i would run stock gears until you can afford a 12 bolt... then i would step up to 4.11 or 4.88
ChrisFrez
03-22-2015 09:12 AM
