as&m with BMR K-Member random tech y clearance
Hey guys, I've been searching all morning trying to see if this has been covered before, I haven't been able to find the right search terms if it has.
I've got the motor out of the car and am assembling everything on it so that I can put it in from the bottom. As I started putting the AS&M driver side header on, I noticed it is extremely tight clearance on the BMR K-member and also, when I put the random cat Y on, it makes contact with the oil pan so that doesn't seem right either. I haven't torqued all the bolts down yet, but i don't think I can get that much more clearance on it by torquing it down, all the bolts are on tight. on the header. Any thoughts ?
I've got it all torqued down and i'm still getting contact on the driver side of the oilpan. it looks as if I may need to have to have the ypipe cut and rebent a bit.
Sometimes buying used stuff saves money, but leaves you kind of in an unknown situation. I'll post pics later for future reference for others.
