pacesetter lt install
i broke what i think is the oil pressure sender, i got the headers in and on but i dont think that the oil sender will fit in, it is so long and if it does fit in it will be right agains the header that will melt that, i am wondering what to do, i will order a new on on monday but i dont think it will work, any input would be great thanks
mine broke when we were doing my header install... luckily i had a gm master tech helping me haha... he got a 90* pipe bend and put it in the hole with it pointing towards the front of the motor and made it so the sending unit is also going towards the front of the motor instead of straight out towards the header
my wires 5 and 6 are very close to hitting the header 5 is touching so i am wondering what my options is anyone running stock wires and if so what could i but inbetween there to help if i fired it up now it would burn 5 for sure.
I had to tie off a couple of wires to make sure they didn't hit the header tubes on my old 96 SS. I also put some heat wrap around one wire just in case. Take your time and do it right so you don't have to replace anything later on.
i didnt have that problem with the sender maybe its an issue on earlier cars? and if the boots are touching you will be ok. i started mine up expecting to burn multiple wires immediately and it never happened, even a year and a half later. when you replace them though you will want to do an over the valve cover routing.
