Where to find breslim header bolts?
Old 06-04-2007 | 04:56 PM
onetransam4u2nv's Avatar
Ive looked all over for breslin header bolts for the lt1 which no luck everones seems to discountinued them. any help would be great.
Old 06-04-2007 | 06:24 PM
useful_idi0t's Avatar
i ran into the same problem last year trying to get some for my header install that never happened. could not find a single vendor that carried them. if you find some let us know
Old 06-04-2007 | 06:25 PM
2000GTP's Avatar
Last I heard, they shut down. You may be hard pressed in finding a set.
Old 06-04-2007 | 06:33 PM
ttop1986's Avatar
I think I got mine from Victory Racing Engines over a year ago.
Old 06-04-2007 | 06:47 PM
wrd1972's Avatar
They are no longer made, next best thing is stage 8's, they re a SOB to install but they work well.
Old 06-04-2007 | 07:13 PM
dam that really sucks
Old 06-04-2007 | 07:24 PM
96capricemgr's Avatar
Be vigilent tightening the bolts frequently for the first couple weeks. Bolts don't loosen till the gasket compresses and causes a lose of torque on the bolt at which point they can begin to loosen.
You guys looking at fancy bolts are halfassed treating the symptom rather than the problem.
Repeatedly tighten the bolts as the gaskets compress from the initial heat cycles and the bolts will stay tight after that.
Old 06-04-2007 | 09:17 PM
SevenStars's Avatar
I got a set with 1k miles on them I pulled off my parts car... if any ones interested pm me an offer I guess
Old 06-04-2007 | 09:51 PM
1997Z's Avatar
What size do you need?
Old 06-04-2007 | 10:39 PM
RUDEDOG's Avatar
I used stainless allen head bolts from home depot with flat and lock washers and they have never loosened up.
Old 08-19-2007 | 06:23 PM
Steve in Seattle's Avatar
Post
Breslin is MIA... went belly up.
Stage 8's are crap, you can't even get the lockers on every bolt with most LT1 headers.
ARP 12-point 1.5". Tighten twice and you're money.
HectorM52
07-30-2017 11:46 AM
HectorM52
06-23-2016 08:42 PM
maybe2fast
03-16-2015 09:45 AM
SavageZ28
17
07-14-2002 11:04 PM
Quick Reply: Where to find breslim header bolts?
