10.8:1 CR + s-trim maxed out
Old 04-28-2007 | 08:59 PM
blazzen's Avatar
10.8:1 CR + maxed out s-trim, 93octan w/ water/alcohol, and coated Dimond's, is this a bad idea? Should we (my brother's car) keep boost down to about 8#. Or is this to much for that CR also?
Old 04-29-2007 | 12:21 AM
VK's Avatar
VK
I would try it, just be careful and slowly get into it and if it starts detonating then let out of it and lower the boost.
I ran over 10psi to a 100% stock bottom end lt1 w/ ~10.7 SCR and after a few weeks I spun a few bearings but when i tore it down, the pistons were still 100%.. ring lands and all!
Tuning is going to be your main factor... then perhaps weather.
Old 04-29-2007 | 02:40 AM
engineermike's Avatar
Should be doable with straight meth.
Old 04-29-2007 | 12:26 PM
blazzen's Avatar
Well we'll probably try it like that, slow at first then let it rip.I hope it doesn't blow up on hot day. Would getting 2 tune's be a good idea? 1 for normal temperature's, and 1 for a hot day @ the track, pulling more timing out for safety.Then all id have to do is upload it to car from laptop? or is that a stupid idea.
Old 04-29-2007 | 12:39 PM
With Buick guys running 28 psi boost and DSM guys running 45, I don't think 8 psi on 11/1 compression is that bad if you're putting in enough Meth.
Mike
Old 04-29-2007 | 12:54 PM
blazzen's Avatar
Mike
You seem to really like Meth, so we'll do some more research on that stuff,water/alchol sounds easier to get my hands on, but if meth is what works best then g..damit meth it is.
Old 04-29-2007 | 03:08 PM
cjmatt's Avatar
Methanol is alcohol. Just run it straight
Old 04-29-2007 | 04:10 PM
blazzen's Avatar
Ok im retarded.But thanks for that info anyway.
reww86
06-24-2015 07:45 AM
FredM
06-05-2015 05:45 AM
NewsBot
05-29-2015 01:40 PM
chelsea94camaro
V6 Tech
08-23-2002 11:08 AM
Quick Reply: 10.8:1 CR + s-trim maxed out
