1000+ rwhp
#16
No it is completely cool and I appreciate that you are not trying to persuade me. I am sold on the STS kit anyways. I have been to your site when I first started this project and what turned me off from front mont was all the piping running through the engine bay. I also want to keep my a/c and maintain my clean engine bay since I have relocated the battery, power steering reservoir and the fuse box all to make the bay cleaner looking. I have also deleted the abs and am currently reworking the a/c lines for a cleaner look.
#17
Has anyone on here heard of a quick spool valve. I will be using this to help spool the turbo/s faster. Here is the link to check it out.
http://www.spracingonline.com/store/...ool_Valve/3643
#22
I have been really thinking about how I am going to route the piping to the front from the back of the car. I cannot find a way to do so that I like that will not possibly interfere with ground clearance. I don't want to seem like I am going back and forth but I have not really decided and I am really thinking front mount turbo or procharger F1. The problem with with front mount turbo is the pipes are still going everywhere and my first choice before I even posted was procharger F1.
#23
It might look like pipes going everywhere on some of the builds- but that is because there isn't a body around the motor to hide a lot of it. From what you see when the hood is popped it will look clean.
If I were to lay out all the pipe from my engine bay it would look like a lot with the FMIC- but all you can really see from above is the single pipe going into the TB.
#26
A purpose built rear mount setup can most definitely make over 1khp; many STS cars do. An STS powered C5 with a tailormade kit holds a land speed record at like 264mph, I think it was like 1600rwhp or something. If you like the benefits of mounting the turbos out of the engine bay then go for it. If you like the benefits of a huge procharger then do that.
Any type of setup can be made to meet your power goals so it really comes down to weighing the pros and cons of each system for your car, and your own personal preference.
#27
https://www.camaroz28.com/forums/sho...d.php?t=757634
#28
All the more reason to do it then.
I also got ahold of american power train today, so my search for a t-56 is over. I am ordering a magnum t-56 that is rated to 1100 torque and one of their twin disc science friction clutches w/ billet flywheel that is rated the same. They sell the complete kit to swap out the 4l60E and it is at a reasonable rate so I am good to go on this now.
Also I have gotten ahold of everyone besides procharger and I will hopefully start ordering soon. I am looking at winter for the build so I can finish up the summer with a running car.
#29
Take it from someone who has built a couple of 900+ hp combo's (including an LTx). . . there are more than a few advantages to the SBC and LSx platforms. The raised-runner 18 deg SBC and L92/LS7 heads are all light-years ahead of anything you can get for the LTx. Every cylinder head for the LTx still uses the 1950's runner entrance and valve location/angle.
Mike
