396ci LT4, YSI and 15lb of boost dyno result :(
Old 08-22-2010, 10:02 AM
  #31
Moderator
rskrause's Avatar
That's about what you should have expected. 35 degrees is WAY to much timing. Run low 20's and disable the knock sensor. CR is fine.
Rich
rskrause is offline
Old 08-23-2010, 07:57 AM
  #32
engineermike's Avatar
1. What cam did you go with? (I still think the smaller cam will lose power)
2. That XS intercooler has its own issues. The water outlet is at the center of the tank. That leaves a large air pocket, where no cooling takes place. If you intend on keeping the XS, then redrill the water outlet at the very highest location possible. I eventually replaced my Vortech aftercooler with a Bell unit, which was 2.5x the size and 2x the flow area.
engineermike is offline
Old 12-29-2010, 04:48 PM
  #33
kazdevil's Avatar
Re: 396ci LT4, YSI and 15lb of boost dyno result :(
solid roller cam fitted.Cam specs are 236/247 .632/.668 114 (+4) .Bullet VS 3100 solid roller springs and Ti retainers.gain wasnt much.Rev limit kept at 6700 RPM. IAT 27-30 c. same spark timing.Next step is bigger intercooler.
http://www.ls1tech.com/forums/attach...am-ls1tech.pdf
kazdevil is offline
Old 12-29-2010, 06:44 PM
  #34
4SFEDZ's Avatar
So u picked up 5hp and 8 ft lbs goin from hyd roller to solid? Guess that answers my question. I'm stayin hyd!
4SFEDZ is offline
Old 12-29-2010, 08:25 PM
  #35
RealQuick's Avatar
Originally Posted by kazdevil
gain wasnt much.
peak numbers weren't a big increase, but you picked up a ton of torque down low! Definitely an improvement.
RealQuick is offline
Old 12-30-2010, 06:53 AM
  #36
97SS0594's Avatar
in to track this im running roughly 22psi with my F1A but just changed to an auto from a 6 speed... i want to change my cam
97SS0594 is offline
Henson071
08-04-2015 09:32 AM
RallyRed701/2
07-27-2015 02:55 PM
13qtr
07-19-2015 05:30 PM
Strick
07-14-2015 07:28 AM
Quick Reply: 396ci LT4, YSI and 15lb of boost dyno result :(
