52cc heads what should i do for shortblock
Old 05-30-2005 | 09:25 AM
simple's Avatar
355-357cid shortblock (either 3.48" or 3.50")
probably GM forged 1 piece crank (maybe Eagle) hell might even use a stock worked over crank...
forged rods
forged pistons
help me figure out what size rod and piston i will need too get my motor too live under boost (cam will obviously be changed)
i'm thinking 5.7" rod too keep the pin as low as possible and a deeply dished
forged piston because of the chamber size of my heads?
stock deck height (maybe), Cometic gaskets, D1 blower, ALKY injection, custom grind cam
Old 05-30-2005 | 11:07 AM
rskrause's Avatar
Moderator
Re: 52cc heads what should i do for shortblock
With chambers that small you will need pistons with the biggest dish you can find. I have had good results with the JE -31cc "blower" piston. Put it 5 in the hole and use a ~0.040" gasket and you will have ~8.8:1 if you stick with a 3.48" crank.
Rich
Old 05-30-2005 | 11:45 AM
LittleRedZ's Avatar
i got 53cc heads on my car, 5.7 eagle 4340 rods and .-33cc custom dished Je pistons
9.1:1 comp
Old 05-30-2005 | 12:09 PM
simple's Avatar
thanks Rich
littlered, is the block still stock deck height? and what gaskets are you using?
Old 05-30-2005 | 12:52 PM
LittleRedZ's Avatar
Originally Posted by simple
thanks Rich
yes stock hight, i'm using cometics
DirtyDaveW
03-15-2015 07:01 PM
Roadie
02-16-2015 10:34 AM
Chevyguy358
01-28-2015 08:04 PM
NewsBot
12-28-2014 06:20 PM
Queens94z28
11-20-2014 06:03 PM
Quick Reply: 52cc heads what should i do for shortblock
