Is 700fwhp w/ this setup/application possible?
Old 10-03-2005 | 09:20 PM
  #16
engineermike's Avatar
Re: Is 700fwhp w/ this setup/application possible?
I'm not going to argue that the stock PCM is better than aftermarket, just that it works quite well and requires way less tuning time. The aftermarket PCM's have way more capabilities, but require alot more setup time, money, wiring, etc...
The stock PCM has tables for fuel versus temperature plus other things. Is that the different conditions you referred to, ramair96ws6?
Also, Craig Moates has devised a way to log and tune the stock PCM on the fly.
Mike
Old 10-03-2005 | 09:37 PM
  #17
ramair96ws6's Avatar
Mike
no **** is there a lil more info on this? thats pretty damn cool. didnt want to start any **** just makin suggestions thats all.
I love using F.a.s.t. stuff its so damn easy to use and it can make so many corrections its crazy.
not alot of people can do stock pcm tuning
Old 10-03-2005 | 10:01 PM
  #18
Here's some more info on Craig's stuff:
http://www.moates.net/index.php?cPath=24_47
" APU1 AutoProm Package: USB Version
Does everything in one package, one USB-based device! USB-powered, so no power supply needed. Chip burning/reading, datalogging, and realtime emulation. "
Old 10-03-2005 | 10:04 PM
  #19
CamaroSS30thAnn's Avatar
its alittle different but my buddys LS1 out over 600 at 10lbs
Old 10-03-2005 | 10:33 PM
  #20
I know you can make great power with a stock pcm Ive tuned a ls1 with a f1 to 750 rwhp at 17#s of boost it was a monster lol. I have a lot more time on LS1 stuff compared to lt1. I just love the aftermarket stuff for big HP
Old 10-03-2005 | 10:59 PM
  #21
ZBLKHELLRZR's Avatar
Wow didn't expect all the responses. FAST would be nice also but the limiting factor being the $$. No need for me to reinvent the wheel if I don't have to for the time being meaning if I can get away w/ the stk pcm & 60lb inj w/ out issues then that's the route I take for the time being.
Old 10-04-2005 | 06:37 AM
  #22
JustNO's Avatar
is 255lph single pump enough for 700bhp ?? Or dual 255lph pump is required??
Old 10-04-2005 | 07:25 AM
  #23
Based on the research I've done you can get away w/ the 255 but you'll need some type of boost-a-pump. I think that's one the ragged edge though BUT it works. Most big hp folks running around here do that at the minimum but seems the best way is a dual pump w/ -8an lines etc.
Old 10-04-2005 | 05:19 PM
  #24
DiabloGT's Avatar
what about for 1200 fwhp what size injectors and fuel pump?
thanks
Old 10-04-2005 | 05:23 PM
  #25
JustNO's Avatar
100lb+
Old 10-04-2005 | 09:02 PM
  #26
mzgp5x's Avatar
Running a 383ci D1 15psi with 72# Low_Z and a versafuller. 1997 with Lt1 edit. I had to go with 2 - 255 LPH in tank pumps and a single KB BAP on pump #1. What really helped is re-plumb of the stock set-up from the tank. The stock small line is very flow restrictive. Also running a M6, and maybe going with a Moser rear.
Old 10-04-2005 | 11:53 PM
  #27
Where did you get the intank dual pumps from?
Old 10-05-2005 | 05:54 AM
  #28
I built my own dual intank 255 setup. It doesn't take a whole lot of creativity, a hose clamp, and a "T" to make it work. However, with the stock fuel lines, you have to trigger one on boost.
Mike
Old 10-05-2005 | 08:09 AM
  #29
RealQuick's Avatar
Mike
Any more detail on the setup Mike? Wiring schematic perhaps on how the 2nd one was wired up? Also, did you fit them both in the bucket?
Old 10-05-2005 | 11:26 AM
  #30
Schurters LT1's Avatar
this should help
http://www.ls1tech.com/forums/showth...l+pump+install
Quick Reply: Is 700fwhp w/ this setup/application possible?
