Adjusting the hobb switch
Old 11-23-2006 | 09:57 AM
xxsaint69x's Avatar
Which way do i need to tighten or loosen the screw to make it activate with higher boost? Right now i have it set to kick in the 2nd walbro at 4psi, which is way too early...i am trying to have it come on around 10psi. Will one walbro be ok up to 10psi?
Old 11-23-2006 | 10:18 AM
cjmatt's Avatar
tightening increases the psi itll come on at. im good with one to 10psi, but all engines are different, youre making more power, so youll need more fuel, whats wrong with it coming on at 4psi? its going through a fuel pressure regulator so it shouldnt hurt
RUENUF
03-13-2016 03:37 PM
Quickss96
01-29-2016 05:56 PM
Rod Bender
25
09-16-2015 01:47 PM
Steve69SS396
Track Kill Stories
08-17-2015 08:48 PM
Jlo
07-29-2015 03:52 PM
Quick Reply: Adjusting the hobb switch
