Another LT1 Boost turbo build
#34
I contacted a local place, Synapse Motorsports, about doing a few power pulls once everything comes together. Knock on wood, it'll be the 12th (next week). I am not loading up on a dyno on friday the 13th.
I got the idea for them from you, and I gotta say it was a pretty brilliant idea.
Originally Posted by Procharged94Lt1
I like your headlights...and the turbo is pretty cool too..that will be my next project.
#36
#37
https://www.camaroz28.com/forums/sho...d.php?t=754516
Originally Posted by RealQuick
What's the plan for tuning Geoff?
#39
I've been up to Kennedy's before, but I know the guys at Innovative Tuning pretty well and they've been much more receptive to working with me than Kennedy's has been and their time/monetary demands have been *much* more reasonable.
#40
#41
No, no ******* dyno at all.
The car has now decided it won't hold an alignment anymore (seriously, trying to roll up a pair of ramps with the front wheels throws the front drivers side wheel off by 10-15 degrees) because the A-arm on that side just won't torque down and stay in the K-member. I've dealt with this issue and BMR back and forth several times now and they keep sending me different shims and bushings and it's just not freaking working.
While it's at it, there's now something that smells like it's burning on the front driver's side of the engine (that wasnt there two days ago), but I can't find anything or see anything, and with the wheels way the heck out of whack (its bad, let me tell you) its getting hard just to get the stupid car back into the garage so I can get it up on stands (as ramps are out of the question).
Oh and on top of it, if I run the car for more than 2 minutes- when I stop and pop the hood, there is air/bubbles coming out from the top passenger side water pump bolt.
Oh and the poly locks are still getting loose, even though I torqued them to spec. I'm considering using locktite on them.
I'm going to set my car on fire. I just want to drive it under full boost ONCE this summer without something going wrong.
#42
10-31-2016 11:09 AM
