Any thoughts on sheetmetal intake for FI cars?
Old 11-30-2003 | 12:46 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
I've got a sheetmetal LT1 intake down at the shop that I'm thinking of trying out. It's got much more plenum volume than the LT4, and the runners are 3 inch, slightly tapered.
Any thoughts as if this will be much benefit on a turbo car?
Old 11-30-2003 | 01:24 PM
kmook's Avatar
Advanced Tech Moderator
Any improvement is good but on a FI car a sheetmetal intake is going to not be that big of a help over a LTx intake vs. a n/a application.
Id say forget it if you were looking at buying one for $2k+, but since you have one already, definately do it. They also look good
No idea on what kind of actual #s youll gain, i hope you get it on a dyno soon after and let us know. How much boost are you running?
Old 11-30-2003 | 01:38 PM
INTMD8's Avatar
Yeah, I agree that it would be much more beneficial on a naturally aspirated setup.
Just looking into the LT4 intake, the plenum seems small, and there are alot of obstructions. The plenum necks down after the TB, the wall at the top for the fuel line crossover, there are also 'bumps' above the port dividers.
Also, the angle of the sheetmetal intake ports are higher than the LT4.
Old 11-30-2003 | 02:11 PM
89ProchargedROC's Avatar
Maybe you'll get lucky and get better airflow into the heads and a better overall VE and pick up some power....not outta the question but not worth the cost new
but since you have it there, its just the cost of gaskets
let us know how it works out
onefastgta
03-19-2015 10:10 AM
pologreen97z
12-02-2014 10:42 AM
tds1213
11-27-2014 12:55 PM
thenewkid
11-27-2014 09:41 AM
USAirman93
11-24-2014 03:37 PM
Quick Reply: Any thoughts on sheetmetal intake for FI cars?
