Anyone ever upgrade from an ATI 2 to an ATI 3 core IC?
For those of you that did....
Did you loose or gain any boost?
More importantly, did you notice a significant decrease in IATs?
And how much boost were your running?
Thx,
Claude
Thx,
Claude
I ran an ATI 2 core IC with a p600b. Could not get what I wanted even with small pulley combinations. The p600b had a very small dia input shaft and key. Then, changed to a D1 with a 7.6pd to 3.4pd. Purchased a 25x8x3" Spearco IC (a tight fit on 4th gen F_bod) which really dropped the flow friction and pressure drop. I've also added methanol/ h20. I did all the piping with steel light gage 3" dia tube (3 1/2 on intake side). I had a big problem with flex intake tube collapse under suction. This really helped flow, and, I was amazed @ the increase in air flow performance. I see about 14psi @ 6500rpm. (97ss 383 - D1) B.
ducttape1975
07-10-2015 06:29 PM
