Anyone running ysi on t-trim kit bracketry only...no BB hub?
Old 05-31-2007 | 02:10 PM
cjmatt's Avatar
Hey guys,
well I just got off the phone with vortech and it appears that my t-trim is F-ed in the A...They didnt reccomend rebuilding it, so anyhow, now it looks like ill either be spending 2340 on another t-trim or else 2620 on a ysi, why not go bigger huh?
that brings me to my next question, I am wondering how dangerous itd be for me to run the ysi on my motor...it is built mechanically to handle it...callies dragonslayer crank, compstar rods, and diamond pistons...BUT, i am using the lt1 hub and the dragonslayer is single keyed, plus id be bolting it into the bracketry from the t-trim....
How crazy am I to want to run about 15-18 psi off of a ysi on this setup? i just dont want to rip my ati balancer off the front of an expensive *** crank like the slayer
Old 05-31-2007 | 11:41 PM
cjmatt's Avatar
anyone?
Old 06-01-2007 | 08:43 AM
Schurters LT1's Avatar
YSI will NOT fit the T-trim bracket with out major mods...and if you get it to fit the braket will flex...
give Z8 an email and ask him for his brackets......
the YSi is not just a bolt on...
Old 06-01-2007 | 09:13 AM
RIGRUNNER's Avatar
Here is mine on the stand. It is in now(not running yet) and all seems to be ok.I have teh ati hub that is dual keyed and a whole lot thicker wall that the stock replacement. You have to bore the timimg cover and it comes with a new seal. If you need or want more pics or info just let me know. I have a couple extra sets of pulleys if anyone needs them.
Old 06-01-2007 | 12:03 PM
cjmatt's Avatar
Does ATI have a big block hub that is single keyed? I know my crank is only single keyed and im not going to go through the hassle of pulling it.
I would however upgrade the front bracket, pullies, and toss on the ysi if i had to
Old 06-01-2007 | 07:29 PM
97WS6Pilot's Avatar
The big block hub that Lonnie sells only has a single key.
Edit: Oops. I forgot it had two keyways. I only used one key.
Old 06-01-2007 | 09:03 PM
Lonnie Pavtis's Avatar
Actually they are double keyed, but you do not have to use both of them.
Old 06-02-2007 | 09:38 PM
whonxt?'s Avatar
Nice setup, it looks like you have more distance away from the end of your crank w/all the pullies and spacers than I do w/my D1SC kit. If your stuff stays on then mine should be okay!! Nice looking motor!
Old 06-13-2007 | 09:06 AM
cjmatt's Avatar
bump, got the ysi today, havent heard from rigrunner in a while so i may still need someone to make me up a bracket
Old 06-16-2007 | 10:46 AM
bowtiepwr's Avatar
>So do you think using two brackets sandwhiched together would prevent flex?
either take off the bracket from Vortech for the S-trim or T-trim and fab another or get another and bolt them up using longer bolts.
could it be that easy??? probably not.
Old 06-29-2007 | 05:09 PM
RIGRUNNER's Avatar
Your bracket shipped today. Sorry I have been very busy the last couple weeks. I has shipped and I will give you the trackin # as soon as I get home. Sorry about the delay.
Old 12-25-2007 | 03:54 PM
Highlander's Avatar
How much for that bracket?
HectorM52
07-30-2017 11:46 AM
10-31-2016 11:09 AM
01-23-2015 01:13 PM
CARiD
01-14-2015 04:00 AM
12-04-2014 11:56 AM
Quick Reply: Anyone running ysi on t-trim kit bracketry only...no BB hub?
