Anyone using an S400 75mm on 1.10?
Looking at the Majestic special?
I know plenty of the 351/357 Ford guys are using it. Should see similar results.
355-383 I would expect a little lag but honestly not bad. Full boost 3500-3800ish. Also give the guy a call if that is the one you are looking at. Dave (I think is his name) is real helpful.
Ya I was thinking about it, the price is really drawing me in! I cant find a Prescision T76 for under 1K and for my first turbo build I was hoping to go a little cheaper that way if I screw something up Im not out a 1K+ on a turbo.
Two options on the cheap. The master power t70 or the borg warner s400. Wish there was one in between the two.
I went with the t70. I know I will be limited to about 600 to the wheels, but even with my early tuning I have learned this thing comes on like spray. My car will always be a street car, so my choice was easy. I have logs showing 10psi below 2k rpms... Some of those oopsie moments.
A more drag oriented car and I wouldn't think twice about using the s400.
The GT42 is a 70mm wheel with a huge housing, should put you somewhere between the two performance wise. You can find them cheapish, maybe not as cheap as the MP T70 though.
Ya thats pretty damn cheap, If I toast $600 bucks it isnt to hard on the wallet. I can pick up two of those for the price of one Prescision.
