bigger intercooler making me run more rich?
Old 09-07-2010 | 10:56 PM
97SS0594's Avatar
ok so my car is a LT1 355, F1A procharger, LT4 heads intake ect.. had the car tuned with the 6 speed in it and the dinky twin intercoolers. i have since put in a fully built 700R4 full manual valve body and a 31x12x4 front mount with 3 inch aluminum piping, car is tuned in speed density. after the new intercooler the car is running at 10.5:1-12.2:1AFR at idle and fouling plugs. is this something the bigger intercooler will cause or should i be looking somewhere else?
Old 09-08-2010 | 09:54 PM
MysticBowtie's Avatar
I just had mine tuned in speed density last week, so I'm still learning about it. However, when I brought it home and unloaded it from the trailer, I had to pull the air filter to clear the ramps. The car idled like crap and I attribute that to the free flowing air. With the filter back on, it ran as tuned. I wonder if your FMIC is flowing better, causing your tune to now be out of whack...? I understand that speed density is touchy. Just a thought, hope it helps.
Ben
Old 09-09-2010 | 07:42 AM
Fastbird93's Avatar
This is early morning thinking here, but you could be seeing a larger pressure drop across the single big intercooler, thus less air in the motor at idle/ect would equate to a rich condition. Again, I'm not awake, I'm sleep-posting this in case it's out to lunch.
Old 09-09-2010 | 09:42 PM
97SS0594's Avatar
we had my fuel pressure turned up to 60 psi so i turned it down to 56-57psi and the idle afr is at 13.1:1 now, it still seems like im popping in the headers though occationaly, its not picking up any knock at idle untill i give it some gas and i get some burst knock, i think at 4-5 quick blips it read 4000 knock which to me thats realy not that much. the timing is jumping between 22 and 28.
DirtyDaveW
12-01-2016 05:37 PM
10-31-2016 11:09 AM
TYLER94Z28
12-03-2014 07:05 AM
1LEThumper
07-14-2003 12:45 PM
BLOWNBIRD
05-28-2003 01:02 AM
Quick Reply: bigger intercooler making me run more rich?
