bolts on the crank pulley keep coming loose
well I everytime I tighten the crap out of the bolts for the procharger crank pulley it keeps vibrating loose. already lunched one belt. I have the spacer on and everything. any ideas? also does anyone else besides procharger carry crank pullys like 8 rib 12 rib etc.
Re: bolts on the crank pulley keep coming loose
well the last time it came loose it hit the motor for one of the fans and damaged the ribs. I thought that i had the pretty tight because i could see the other end of the bolt coming through the factory crank pulley but i didnt tighten it anymore because it would have come a little too close to the opti
