Boost question???
Old 08-09-2008 | 09:02 AM
bski224's Avatar
Boost question???
At what RPM point does boost really get going for you guys???
Old 08-09-2008 | 09:35 AM
jay_rich's Avatar
Well what kind of setup? Everything is gonna spool different.
Jay
Old 08-09-2008 | 09:54 AM
chasmosis1's Avatar
Agreed. With a Supercharger you will see boost continue to increase until you start overspinning it and loosing the efficiency. Turbos, however, are very different .
Old 08-09-2008 | 01:23 PM
bski224's Avatar
P-600B Hotcam/Head work etc.... Only pushing approx 6lbs
Old 08-09-2008 | 01:30 PM
StripedFomula's Avatar
p600b on stock internal lt1 with 8 lb pulley. start seeing a lb at 3000 and builds to 7lbs at 5800-6000
Old 08-09-2008 | 01:41 PM
bski224's Avatar
Excellent thanks dude!!! Is there a way to check my bypass valve while car is at idle??
Old 08-09-2008 | 09:39 PM
i am not really sure, i have mine set to vent to the atmosphere. i can plug and unplug the vac line and watch the arm move the valve open and closed positions
DirtyDaveW
12-01-2016 05:37 PM
10-31-2016 11:09 AM
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
06-06-2015 08:27 AM
Quick Reply: Boost question???
