Building another LT1...which pistons this time?
Looking at building another LT1, and want to be somewhat on a budget.
It will be another MP build, but this time...a street car.
Looking at either TRW speedpros, SRPs, MAYBE JE, or diamonds. Only looking at running 10-12 PSI, so i dont need a crazy piston.
I know speedpros are good, built strong, but they are heavy and are the cheapest
SRPs i know have a high silicone content and do not like detonation
JEs and Diamonds i know are strong, but pricey
More than likely, going to either run stock rods, or forged i-beams.
Trying to keep internals under a grand this time
what size engine? 355 or 383?
I picked up some parts for a 383 a while back, but never used them. Brand new Lunati custom pistons (4.030" 2618 alloy -30cc 5.7" rods O-shaped dish) and a new set of Eagle 5.7" 4340 H-beams with L19 rod bolts.
If interested, PM me and we might be able to work a deal...
I was going to go 355 just because i already have a t70, but if your price is right....
This is the piston I think you want
PT007H3 355 5007H3 4.030” 3.480” 6.000” 1.260 -20cc 8.5:1 8.7:1 4030H
from this list http://wiseco.com/Catalogs/ProTru/Bu...rChevrolet.pdf
How can you scrimp ($$) on internals? Seems to me that pistons are the most important part of an FI engine build. Set your specs into writing, do the math, and find the proper piston. Don't worry about cost, those dollars will be eaten up in two tanks of gas, or less.
