Compressor Maps?
Compressor Maps?
Can somone help me understand what this compressor map means?
http://www.atpturbo.com/root/maps/im...8rcompress.gif
http://www.atpturbo.com/root/maps/im...28rturbine.gif
Max amount of air is ~70 lbs/min, which is about 760 crank hp. Assuming your redline is 6000rpms, it will require ~16-17psi of boost. Of course this is just an approximate, and at those PR's and flow rates you are pushing the turbos to the max and then some.
Jose
Jose
tdigger9899
09-07-2015 10:56 AM
