Couple of teaser pics.....LONG build finally ending
Old 08-14-2010 | 09:19 AM
  #16
Rob94hawk's Avatar
Originally Posted by MikeGyver
Don't need ABS to be legal, my damn ABS never worked anyway so the decision was an easy one for me lol. Freed up more room than you'd think and makes it incredibly easy to work on that side of the motor, but mainly I did it so I could run a 3.5" tube to my intercooler.
BTW, If you have a build thread I'd like to check it out.
Very clean! Love it. Is there any way you could re route the stock fuel lines?
Old 08-14-2010 | 10:16 PM
  #17
MikeGyver's Avatar
Yeah I need to put that on my long list of stuff to do that will never get done.
Old 08-14-2010 | 11:16 PM
  #18
MysticBowtie's Avatar
It only takes 30 minutes brother, you got it!!
Old 08-16-2010 | 09:29 PM
  #19
Fastbird93's Avatar
Question man -- How high above the radiator shroud is that intake pipe sitting? I'm looking at doing something similar to my car though it's merely about routing more so than fitting a larger pipe in (3" should be plenty sufficient for some large numbers).
Old 08-16-2010 | 09:54 PM
  #20
Bersaglieri's Avatar
I've got a 4" pipe kit for sale, it would probably save you alot of time. Let me know.
-Dustin-
Old 08-17-2010 | 01:02 AM
  #21
MikeGyver's Avatar
Around an inch, and about 1/4" higher than the throttle body inlet.
Old 08-17-2010 | 10:30 AM
  #22
Fastbird93's Avatar
Good stuff. Rather than try to route my pipe through the gap between the radiator and ABS Block, I'll probably go on the top side then as the 3" pipe I'm using barely sits above the shroud.
Working on the cold side this week......
Old 08-17-2010 | 11:33 PM
  #23
MikeGyver's Avatar
maybe you can move the ABS brick back an inch or 2..
Old 08-17-2010 | 11:42 PM
  #24
97WS6SCharged's Avatar
You could always stand the radiator up straight.
Old 08-18-2010 | 07:28 AM
  #25
Fastbird93's Avatar
can't move the abs block back much at all....downpipe clearance is tight. Not going to stand up the rad.......am keeping ac. The 3 inch pipes I'm usig are goin to work fine....was test fittin last night and I can go top side of the tight spot or go on the low side just above the radiator hose.
Old 08-27-2010 | 08:18 PM
  #26
Fastbird93's Avatar
Not quite over, but it's ALIVE!!!
http://www.youtube.com/watch?v=MEW7UnZRsPo
Bad IAC in this vid from Wednesday, hence the long cranking and no idling on it's own. Put a new on in tonight, played with the XFI, she starts and idles on her own now. Need to get the exhaust closed up to get feedback from the WBO2 it looks like, then I can start with the tuning.
Sounds WICKED at 900 RPM idle.....thinking of taking it to 850 or 800 because it's acting quite nice at 900 still.....
10-31-2016 11:09 AM
importkiller94
01-17-2015 09:03 PM
Collector Car
01-05-2015 10:58 AM
Chris 96 WS6
33
09-03-2002 09:48 PM
guionM
32
08-19-2002 01:39 PM
Quick Reply: Couple of teaser pics.....LONG build finally ending
