dual spal 11" fans?
dual spal 11" fans?
I was lurking over at ls1tech in the forced induction section and ive noticed alot of them have been switching over to the dual 11" spal fans for better cooling. I was wondering if any of my Lt1 people have switched over to this setup. they seem to be having good luck with it. If the fans fit the ls1 radiator wont they fit ours too?
everyone gets the SPAL because of their reliability but there are also other fan setups out there that cost less and work great
If i have to upgrade i'm probably going to go with the flex-a-lite trimline dual fan setup. They are dual 11", pull only 20amps, flow 2500cfm, and are only 2 1/4" THICK, makes for A LOT MORE ROOM
just letting you know there is more out there. Plus the SPAL fans have a diff connector that i believe you have to buy separate. Not sure on that one
Also i am pretty sure that LJ has dual spals on his YS-trim equipped camaro. he goes by 10secondZ or 10secZ on this board
Originally posted by MEAN LT1
Thanks, I'll look at the flex-a-lite fans b/c I do need the room. Do those fans have put out more cfm than the stock fans do?
Originally posted by IDOXLR8
Just remember though if you upgrade to a bigger radiator and decide to run an electric waterpump then you will need the room.
but again, i'm not 100% on that information. I do know that ASSC uses that fan setup when they run big blowers with cogs in their thirdgens because of the space limitations and they dont have problems with them
im not 100% sure but imo yes. From what i have read the stock GM dual fan setup does around 1400-1500cfm or so
Whats the price on the flex-a-lite trimline dual fan setup?
And do they just bolt up and can we use our stock connectors?
Thx,
Claude
I'd love to hear more on this!
I just installed my new Be Cool Radiator and with the 12 rib D1-SC, I had to cut up the stock fans ALOT to get the clearance I needed!!!
I think Summit sells the thin flex-a-lite for like 100 bucks or so??
