eboost users step inside.
thinking about going with the Eboost controller/gauge. anyone use this on a turbo application? i was woundering how it worked do i leave the spring in the wastegate or remove it? is it worth the cash? thanks
I'm pretty sure that you leave it in. Just in case that if the boost controller stopped working, the wastegate would still actuate at the selected spring pressure.
SpeedJunkee
06-06-2015 04:27 PM
