Finally... dyno numbers for the 'Bird!!!
#20
Re: Finally... dyno numbers for the 'Bird!!!
The intercooler that I am using is huge and I have a lot of intercooler tubing. I am very happy as the pulley set up was estimated at 18 psi from Procharger and it made more boost that I was expecting. The motor was pulled to 6500 rpms.
#27
Looks like it should be fun to drive. I'm also curious about the pulley sizes. I'm wondering how fast you were spinning that F1 to see 22psi (seems kinda high), and what belt setup, such as 12 rib, cog, etc.
#29
Yep... still a 6 speed... although it has a Viper mainshaft, a Viper steel 3-4 shift fork, new carbon fiber blocker rings, etc.
The F1 is designed to spin to 70,000 rpms. 22 psi is nothing for that blower.
It's a 12 rib pulley system... no belt slippage.
The blower pulley is 4.12 inches.
Fuel system consists of a Racetronix twin in-tank pump set up with the 2nd pump turning on at 3600 rpms via a MSD rpm activated switch.
MSD 85 lbs fuel injectors
Custom fabricated adjustable fuel pressure regulator.
Custom intake and fuel rail set up.
Stock fuel lines.
This car is far from lean.
Splayed 4 bolt main conversion
Copper head gaskets
ARP fasters
Eagle crank
Eagle rods
J&E custom pistons
Stock fuel lines.
Copper head gaskets
ARP fasters
Eagle crank
Eagle rods
J&E custom pistons
#30
Check out the links below in case you missed them before.
http://web.camaross.com/forums/showthread.php?t=335661
http://web.camaross.com/forums/showthread.php?t=336242
