Fuel/Ignition survey thread plus question about setup
#16
I blew threw 2 Accel stock OPTI's (stock one lasted forever never died should have kept ot) and 3 MSD PRO BILLET Opti's...
ALL DUE TO LOOSE ROTOR SCREWS. Actually, they werent loose to start with but one of the two screws came loose and jam rattled everything around creating nice 6200RPM 7psi (and alot of fuel) backfires.
I noticed on the last two MSD PRO BILLET OPTI's that one of the rotor screws backed out... on the last one only one screw backed out and the other was holding everything together kinda slopily... anyway upon final inspection of all the pieces, I realized one of the two screws didnt have LOCTITE on them... makes sense.
I ordered my final PRO BILLET and dissassembled it and RED locktited the two rotor screws and no problem since.
#17
Cylinder heads I hope to use are advanced induction 200cc ported f body castings...
Blower is a D1SC, ...
Im shooting for 600ish rwhp through a th400. I wouldn't mind making less in the street at lower boost numbers with a larger pulley but when im ***** out at the track, 600whp or more is my goal.
thanks!
thanks!
#18
Im a little paranoid about the aeromotive fpr that I would have to run due to feed/due return lines from my fuel rail and for using the braided line. I hear a lot of bad things about them being inconsistent , leaky, even heard of a guys car going up in flames because of one. However, I don't really know of any other brands that have a better reputation and I do see a lot of guys running them on other high hp blower setups so what is the deal? Is it an "I only run one because I have to" deal or are the problems overblown? I thought I had it all figured out till I saw a thread here reminding me of all the problems I have heard regarding aeromotive fuel pressure regulators.
#19
THANKS EVERYONE! Lot of great info, going to have to take some time to read all of it over again and really think about it.
mzgp5x, do you know if the MSD cap/rotor has the same failure issue as the stock with the brass contact you speak of? I'll have to go out and check out my MSD and see if it has the same plastic welds. I haven't looked at in a while so I can't picture it in my head lol.
Blown 383, thanks for the diagram! That sure takes a lot of the guess work out of it, it'll help me greatly.
UR50SLO, I'd actually love nothing more than turbos but remember it is a B body, full kits go for around 6k and while im trying to learn how to weld I don't trust making my own turbo manifolds. First, I figure the blower setup will just be easier for a F/I novice such as myself. Easier to tune, easier to assemble ect...(even if only by a slight margin) plus its been done many times before on B bodies (and f bodies) so there is a ton of info and parts out there. I also bought a D1SC for about half the price of a new headunit that had only 75 miles on it to begin with, then had it completely rebuilt by procharger for free because of a strange defect pinhole in the compressor housing. So I pretty much made out with a brand new D1SC procharger for half price.
They even threw in 2 packages of new blower oil.
dookie454, thats some great news for me. I'll be running a turbo 400 so it wont be quite as much if everything else is equal but that is impressive for 7psi! Does the blower have any left in it or were you maxing it out? Do you have any problems with belt slippage? ATI doesn't make a bracket that fits the impala so i'll have to make one, im going to start researching options for different belt tensioners as I heard ATI's suck.
#20
I have seen pics of the MSD rotor. Much improved over the stock sonic welded brass rotor piece. I would keep the base gm stock opti and move to an MSD new rotor and cap. I have had problems with other mfg's opti body fitting the front engine cam cover. I made a bad purchase one time of a del_tech (?) opti distrib. Did not fit. Had to mill the cover. They had only 1 rivet engaged in the brass contact on the stock rotor. I run an open tube to vent the opti (a 1997 vented unit). I find better cooling and air flow, but, you need to protect for dirt/ water comtamination.
Hope this helps. B>
Hope this helps. B>
ChrisFrez
02-15-2015 08:12 AM
ChrisFrez
02-15-2015 07:49 AM
ChrisFrez
02-01-2015 08:26 AM
ChrisFrez
01-25-2015 08:06 AM
ChrisFrez
11-23-2014 10:33 AM
