Gen 6 Dfi
Old 02-02-2005 | 06:27 PM
Schurters LT1's Avatar
Gen 6 Dfi
Just looking for some feed back on this system for FI eng...wqhat do you guys think of it
Better then tunercat/LT1edit, would this be the right step...
Would this system work in a daily driver car, with A/C ...M6, how hard is it to tune ,
how well is the O2 sensor for tuning...
Old 02-02-2005 | 07:03 PM
95 Z/28 LT1's Avatar
Super Moderator
Re: Gen 6 Dfi
From what I hear, don't bother unless it comes with the wide-band O2.
Old 02-02-2005 | 07:30 PM
Re: Gen 6 Dfi
He is the kit
Includes:
LT1 DFI Computer
Calmap Software / Cable + Base LT1 file to get you running
Stand Alone Harness
2 Bar MAP Sensor / O2 Sensor (used)
All Instructions for Software and DFI
Low impedance Injector Converter (run low z injectors!!)
Pentium 90 ibm thinkpad (bare bones, but great to use with the DFI)
what do you think
Old 02-02-2005 | 09:00 PM
97WS6SCharged's Avatar
Re: Gen 6 Dfi
I seem to recall something about the early Gen 6 computers not being able to handle 8 injectors at a time or something funny like that. Maybe the memory is a little slow tonight. Anyways, I would check the number on the computer and cross reference it will Accel to see if there are any known issues with the computer. Just my .02
Old 02-03-2005 | 01:06 AM
SSnthe10s's Avatar
Re: Gen 6 Dfi
FAST bank to bank or BigStuff3 is where its at!
Old 02-03-2005 | 07:28 AM
Sean94Z's Avatar
Re: Gen 6 Dfi
Gen 6 DFI is better than using LT1 Editor or TunerCat because you can change the timing/fuel requirements for the boost. It comes with the VIC (Variable injector control) for use of LOW-Z injectors, this allows you to control each injector individually.. It will work on a daily driver car, but, I would look into having someone tune it for you. Getting the wide-open stuff done is easy, getting the car to idle normally and run good when not at wide-open is the hard part..
--Sean
Old 02-03-2005 | 10:43 AM
mongse_1's Avatar
Re: Gen 6 Dfi
I'm using it on a twin turbo 3rd gen and it does the job. Sometimes I feel like I'm playing Space Invaders due to the straight from the 80s interface.
David Dempsey
03-12-2016 12:42 AM
HAWG
09-25-2015 11:41 AM
Z Power
09-19-2015 11:19 PM
Quick Reply: Gen 6 Dfi
