getting rid of fmu and need bigger injectors with tune
I am getting a mail order tune and he recommended ditching the fmu and going with bigger injectotors. I plan on upgrading my heads, cam and forging the bottom end later than sooner. Hoping to get 400 or so HP eventually. What size injectors would be best for right now and also work on the new setup?
I thought 10lbs on stock bottom end = . I found a set of Bosch 36 lb for $300, so what do you think of this brand and size? They say 425 to 475 hp so i would guess they would fall right into my future plans. The injectors are mfg. rated at 36lbs/hr (at 43.5psi, 3 bar), and flow tested at better than 2% tolerance. Bosch 0280150967 - 36lbs/hr Pintle-style Fuel Injectors Matched set.
