Going to the track.
Old 05-12-2006 | 07:17 AM
cg4743's Avatar
Going to the track.
Well if the wife will quit *****ing I'm going to drive an hour away to run a 1/4 mile track tonight. Oh forget her I'm going anyway I'm hoping to be in the low 12's but I'm not sure. I lost boost when I put on the LT's, went from about 5.5lbs to about 3.5 lbs. Just put on the 9# pulley and got back to about 5.5 lbs to 6 lbs. Maybe I'll be able to hit my goal. At the 1/4 mile tracks do they have your 1/8 times on there with the others? Sorry for the newbie question but I had to ask.
Old 05-12-2006 | 07:54 AM
rskrause's Avatar
Moderator
Re: Going to the track.
Your time slip will probalby have the following.
RT
60' time
330' time
1/8 time and mph
100' time
1/4m ET and mph
Rich
Old 05-15-2006 | 12:27 PM
canbaufo's Avatar
2 lb boost loss just from headers?!? Good luck. Let us know how it goes.
Old 05-18-2006 | 09:00 AM
JakeRobb's Avatar
Super Moderator
Originally Posted by rskrause
RT
60' time
330' time
1/8 time and mph
1000' time
1/4m ET and mph
Fixed.
Old 05-18-2006 | 05:20 PM
canbaufo's Avatar
Originally Posted by robvas
I thought only the intake side affects boost?
Boost is merely a measure of how restrictive the engine is relative to the amount of air forced into it via blower or turbo. So when you add headers you reduce restriction because the mass of air as a whole coming from the blower can now get through the engine easier, less restriction so less boost. Even more air is moving through the entire blower/engine package even reading ~2PSI lower on the boost gauge, just more efficiently and at lower temps. More power will be made regardless of the ~2 PSI drop in boost due to the header addition, so he will pick up a lot since he's pullied it up some to compensate.
Old 05-18-2006 | 09:43 PM
cg4743's Avatar
My track times last Friday night were consistantly around 12.35 to 12.4 at around 111 mph. My best was a 12.28 at 113 mph with a 1.78 60'. I was pretty happy with that for my first 1/4 mile visit. It sure does seem like forever when all you've been running is the 1/8 mile tracks. I'll find out Friday night what I can consistantly do in the 1/8th with my newest additions.
karpetcm
08-14-2015 03:02 PM
Cam's maro
08-11-2015 07:45 AM
BMP Mike
01-07-2015 11:12 AM
djcam
N2O Tech
11-01-2002 11:05 AM
kirschman
N2O Tech
12
10-27-2002 12:27 PM
Quick Reply: Going to the track.
