Is this a good cam for a 383?
Old 08-29-2004 | 03:09 PM
xtremetrans's Avatar
I bought a comp cams 224/236 .502/.520 lift and 114lsa from thunder racing for my new 383 with tpis/afr heads, 9.3:1 compression engine. I have a procharger 8psi unit which I will upgrade to about 10 psi later.
Old 08-29-2004 | 07:44 PM
rskrause's Avatar
Moderator
Re: Is this a good cam for a 383?
Yes, I prefer the higher lift version of the same lobes, but it sounds like it should work fine.
Rich
Old 08-30-2004 | 08:38 AM
Should I use 1.6 or 1.5 rr's?
Old 08-30-2004 | 12:08 PM
MEAN LT1's Avatar
I would go ahead and put some 1.6's on it.
10-31-2016 11:09 AM
marineengineer
02-09-2015 03:59 AM
97TA-WS6-Con
02-01-2015 01:01 PM
Queens94z28
11-20-2014 06:03 PM
Fbodfather
25
06-21-2002 04:12 PM
Quick Reply: Is this a good cam for a 383?
