Guess who has become a supporting Vendor...
#31
But honestly.... modern paint tech has come a long way. You would be surprised with just the spray paint.....
#32
My paint and the paint Jon had been using seems to hold up surprisingly well honestly. This kit is aimed at the Do-It-Yourself crowd (aka... budget minded... coatings are never very cheap). So if you want some sort of coating you order it and do it yourself. Save yourself money that way anyways (you don't think he is going to have it coated and not mark up the coating price do ya???)
I want to state though, this stuff isnt a thermal coating, meaning it doesnt provide heat resistance like a coating, but it keeps the outside from rusting (mild steel) and it keeps it nice looking.
#34
#36
#37
#39
The driver's side needs to be changed from the bottom and the pass. side can be changes from the top. Pass. side will take 10 minutes to do all the plugs. Driver's side will probably be 30 minutes since you are on your back looking up.
Jon
Jon
#40
screw that man... im just gonna pull the engine each time i do plugs
when i was putting this engine together and i put the plugs in it almost felt like a sin b/c every other time i have done plug on my engine it was in the car and i usually ended up getting my *** kicked.
#42
#43
I'd rock one!
#44
I dont think itll be that hard, Ill be sending Jon some pics of the passenger side tonight to see what he thinks. Im trying to see if his hot side parts would work in my thirdgen. I was looking at the turbo location for the 4th gen kits and on a thirdgen you have more room to move it out and forward, getting it away from the ICM. I may end up Just doing my own hotside parts or mix and match Jons harder to make parts.
#45
