How Do I Know if my bypass valve is working?
Also, if you disconnect the vaccum line from the by pass valve and pop the throttle, you will hear a pulsing, wheezing sound coming rom the blower.
This is because the valve is closed and the surge is coming back through the blower.
thanks for all the tips, they helped a lot. My next question is this. My car is a 1997 Camaro SS with the LT1 and six speed. My set up is a powerdyne 6.5 kit with the fmu, colder plugs, msd ignition, and a 200 lph in-line fuel pump. With my set-up, what are your guesses as to my performance and hp numbers. My previous best was a 13.56 at 101mph, but more common times were 13.80's. Just your opinion, what am I looking at now?
I guess it would help to have all your mods. I'll try to give a comparison since I have a Powerdyne 6lb unit also in a 95 z-28.
Full interior
BFG drag radials
3.73 rear gears
air bag in passenger side rear spring
6 speed manual
Best of 12.2@114.5 with a 1.8x 60 foot.
Hope this helps.
-Ernest
Full interior
BFG drag radials
3.73 rear gears
6 speed manual
Hope this helps.
-Ernest
CARiD
01-27-2015 06:27 AM
fpete1992
12-11-2014 03:51 PM
