How do you take blower pulley bolt off?
Old 11-28-2004 | 01:48 PM
BMAN'S SCZ's Avatar
How do you guys lock your blower up to loosen the pulley bolt without destroying anything? I have my blower sitting on my workbench if that matters. I was thinking of wrapping the pulley with something to protect it when I grab it with something. Does the bolt have loctite on it? Do I have to heat it to get it off? Thanks guys for any insite.....John.
Old 11-28-2004 | 02:14 PM
Sean94Z's Avatar
Re: How do you take blower pulley bolt off?
I hold mine with a strap wrench.. Loosen the bolt, if you can't get the pulley off, you could try heating it slightly..
--Sean
Old 11-28-2004 | 05:42 PM
Lonnie Pavtis's Avatar
You can wrap the belt around it a few times & use that for traction. Generally holding the belt around the pulley with 2 hands & having someone loosen the bolt w/ an impact wrench works easily.
Without an impact, you will need a strap wrench to prevent pulley damage. Any metal tools will potentially ruin the pulley.
Hope this helps.
Old 11-28-2004 | 07:10 PM
BMAN'S SCZ's Avatar
Thanks guys, I will try that. Also do you loctite the bolt when putting it back together? Thanks again....John.
Old 11-28-2004 | 09:23 PM
I use the blue Loctite.... I forget the number.
Old 11-29-2004 | 11:06 AM
LqMth's Avatar
I just removed the pulley on my sn93 with an impact and it snapped off . Guess I have to drill it out. Anyone know how deep it goes?
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
SpeedJunkee
04-23-2015 09:51 AM
SpeedJunkee
01-27-2015 10:02 PM
1LEThumper
07-14-2003 12:45 PM
Quick Reply: How do you take blower pulley bolt off?
