How much to be gained?
#33
#35
good analogy:
F1 pushing air thru a water hose isn't going to make a whole lot more than a D1 pushing air thru a water hose. Either one of them pushing air thru a 3" pipe will make a whole lot more than the hose. This is dramatized, but makes a point.
#36
Thanks again for giving more insight for those that may continue to believe more boost is the answer for all power solutions.
#37
Either way, since we all knew what you were going to do from the get go anyways, HOW MUCH you want for your heads? I just looked at the AFR 210's that flow 300 from the box and you can get them for around $1600. Im curious as to what yer going to be asking for yours, and a timeframe of when they'll be available?
#38
Like I said, this is all info for speculation. I don't know when. It won't be until at the earliest next year sometime. I will let you know first if I decide to go that route.
Not sure what I'll be asking. AFR's website for the 210's fully ready to go (valves, springs, retainers, ect.) for the competition heads (the ones that flow more than 300 CFM that you are refferring to), list for $2649.00. Not really sure where you can get new ones for $1000 less than that. Mine are 180's fully ported by TPIS, probably flowing slightly less than the 210 competition model. However my springs, rockers, ect. are much more top of the line than what come with the AFR heads from AFR.
I'd honestly have to sit down and figure what it all is worth to me. In the end, probably more than $1600 but I won't know until (or if) that time comes.
#39
But these are the street version, not the competitions. but they do flow 300. The comp's. flow like 310+
#40
http://cgi.ebay.com/ebaymotors/AFR-S...Q5fAccessories
The competition AFR 210's are the ones that will outflow mine (311 CFM), but with the larger price tag.
http://www.airflowresearch.com/sbc-l...c-104_107.html
Again, I'll have to look up records to get the exact numbers, but if memory serves me correct, my heads when on the flow bench did something like 306 CFM.
Don't wait on me if you want heads soon man. I still am not even sure I will be wanting to part with mine. If I do, its gonna be a while.
#41
try this search on ebay: http://motors.shop.ebay.com/__?_from...9&_nkw=AFR+LT4
#44
Those are SBC heads, LT1 versions are typically more money.
colts0455
09-02-2015 12:41 PM
