How restrictive is my flowmaster with D1SC
I have a flowmaster cat back exhaust on my lt1. I believe it is an 80 series muffler. The car has a 396, D1SC, AFR 210 heads with 1 3/4 long tubes. Is this cat back not letting the engine breath? Thanks Lee
I think there are far better options. Will taking it off make 100hp? Probably not. Turbos are much pickier about mufflers than the super charger.
That being said thats a large motor with extra air coming down the pipes. I would def look from something bigger, or dual cutouts close to the collectors.
The car made 496 at 4700rpm. But after 4700rpm, it had spark blow out. I now have installed a MSD box and bryan from PCMforless is going to re dyno it. I did this combo years ago and I only have 8:1 compression. At 4700rpm it had 12 pounds of boost. I think it may make 550hp. Thanks Lee
yes very restrictive! put a cut out on and tune with the cut out open and will prolly see 50hp, a buddy of mine gained 6xrwhp with a d1sc but he is in the 650-700 range
