Issues with SDCE idler pully
Well i started to experience problems with torn up belts... I took the idler pulley off and noticed that it has worn out quit bad from the outside (side closest to the bracket). Can someone describe a way that i can check to make sure everything is lined up correctly?
Ill take a pic of the idler here in little bit.
SpeedJunkee
06-06-2015 04:27 PM
Henson071
05-04-2015 12:23 PM
BlowBye
3rd Gen / L98 Engine Tech
24
07-22-2002 07:56 AM
