just got my z28 dynoed.!!
Old 11-20-2006 | 10:50 AM
  #16
cjmatt's Avatar
Originally Posted by 5.0THIS
I'm really trying hard to be as nice as possible to you, but in short, you have no ****ing clue what you're talking about. This is Colorado bud, our ambient air pressure is right at 12 psi, not the 14.7 you see at sea level. All dynojets utilize standard correction factors, and up here, a 1.2-1.25 correction factor is very common, even in the winter. And in case you dont understand that.. it means that the dyno takes the actual recorded numbers and multiplies them by the above correction factor. him running 7.5 psi of boost up here is the equivalent of running about 4.5-5psi at sea level (in terms of absolute manifold pressure). A boosted LT1 running 4.5psi at sea level making 375rwhp ish, is perfectly realistic.
Actually, supercharged cars suffer equally as bad as normally aspirated cars at altitude. They will have just as much less absolute manifold pressure as a NA car, as the blower isnt spinning any faster to make up for the lost pressure. Supercharged cars merely have an easy way of making up that lost power, by pullying up the blower. As for turbo cars, they do suffer, some more than others. It can depend in large part on the type of boost control system that is utilized. It can also vary depending on how close to being maxed out a turbo is before altitude. If you have a turbo maxed out at sea level and bring it to altitude, it will suffer equally to an NA car. From what I have seen from local turbo guys, a factory turbo car might see ~5-8% loss overall, give or take.
I think what he means is that at altitude, the 7.5 psi seen is the same as if a different car at sea level saw 7.5 psi, which is true, although if you took the high alt car to sea level it would probably show 9 psi , where as the sea level car would only show 7.5 as before.
Old 11-20-2006 | 03:03 PM
  #17
JakeRobb's Avatar
Super Moderator
Originally Posted by Sparkz28ss
maybe I like to give Jakerobb a hard time
Good try, Sparky, but you posted in this thread before I did.
Old 11-20-2006 | 03:14 PM
  #18
Kredz28's Avatar
first...... dont "try" to be nice to me...I dont give a **** if you are "trying to be nice".....all you had to do is explain it to me..not talk to me like Im some dumb****...maybe I like to give Jakerobb a hard time,or maybe I didnt take more then 2 seconds to think about it...... so...my bad....go get ****ed or something
let the flaming begin
Cant wait for 5.0's response...i can tell this is going to be a good thread
Old 11-20-2006 | 06:03 PM
  #19
5.0THIS's Avatar
Eh... it's all good. After his first post in this thread with the nice rolleyes smiley, he had it coming. Besides, he knows now that he didnt have a ****ing clue what he was talking about.
Old 11-20-2006 | 07:52 PM
  #20
JakeRobb's Avatar
Super Moderator
mgray, I think that most MAP sensors measure the difference between local atmospheric pressure and the manifold pressure.
I'm not sure, though. Anyone want to confirm/deny?
Old 11-21-2006 | 08:23 AM
  #21
RealQuick's Avatar
Originally Posted by mgray
So, the boost gauge reads positive boost pressure in terms of measured barometric pressure upon its start, vice an absolute pressure calibrated at manufacture? (no need to be short with me; I am simply asking a question. )
Thats a good question. For people that dont understand, what Mr. Gray is asking is what the guage is using for an "atmospheric" reference. He is asking because the boost gauge displays gauge pressure (atmospheric + additional pressure). So the important question is what is the atmospheric pressure input that the gauge uses.
Old 11-21-2006 | 12:52 PM
  #22
Kredz28's Avatar
Yes, I am also told the map sensor measures barometric pressure before start. Some cars have a separate sensor for this function.
What I am concerned about are analog gauges. If the absolute manifold pressure is given as (barometric+supercharged pressure), the gauge displays supercharged pressure because barometric pressure is the tared zero. At barometric pressure, the gauge displays zero boost/vacuum (the gauge's calibrations will usually have a large zone for zero to account for changes in barometric pressure). Since the gauge, itself, is reading absolute pressure, and the printed calibrations make the displayed pressure relative, for an accurate reading, the display needs to be calibrated to barometric pressure. If a gauge reads zero at 14.7, and each calibration of measure is accurate (meaning a change of 1 psi on the gauge label correlates to an actual change of 1 psi, not 1.2, 1.22, 1.223 etc) then at 12.1, 7.5 psi of displayed, supercharged pressure, is actually 10.1 supercharged pressure.
The digital gauge, mine at least, measures absolute pressure as well. However, upon start, the barometric pressure is set to zero. With any changes in barometric after an off-on cycle, the gauge is effectively calibrated. Of course, this does little for going up and down a mountain. For some reason, I am not worried about this.
The question becomes, is the gauge calibrated to zero correctly? And, are the calibrations between each integer accurate? Even if the gauge is tared to barometric pressure as zero, the manufacturer might have averaged tolerances (scale changes) for barometric pressure changes in each calibration of pressure and vacuum.
hmmm interesting...my guages are the auto meter phantoms, one boost and the other fuel pressure...on the guage, i show just about 8 psi at 5500 rpm...
F'n1996Z28SS
08-23-2023 11:19 PM
Renegade Toker
01-23-2015 10:27 PM
NewsBot
01-11-2015 06:10 PM
01-05-2015 07:14 PM
cmdeshon
01-04-2015 11:15 AM
Quick Reply: just got my z28 dynoed.!!
