View Poll Results: What type of kit would you be most interested in?
Single T4 turbo kit (T60 thru T76)
30.77%
Twin Turbos (using T60-T76)
15.38%
Single T6 Borg Warner S400
46.15%
Single Race Setup (S76-S91)
7.69%
Voters: 13. You may not vote on this poll
LT1 Boost looking for suggestions
What do guys want to see for turbo kits? Obviously the standard T4 T60 - T76 turbos, but what else?
Twin Turbo with T60-T76's??
Single turbo kits that use S400 turbos (since those turbos support 1000hp and only cost $600)????
Single turbo T6 race setups for S series turbos (S76-S91) (up to 1200rwhp)??? You would lose your A/C and need to stand the radiator up vertical as well as run an oil scavenge pump.
What else would you guys like to see?
Jon
Could you get 3.5" downpipe to fit a S400 setup with the use of a BMR k member?
What size down pipe can be used on your T76 header kit witha BMR k member?
Run the s400 with a big 4-5" cutout before the axle and cut it down to 3" to get past the motor? Not ideal for all people but we are doing a similar setup on an ls1 right now.
What about the new masterpower 76? I'm a huge fan of budget builds. Or would it be a direct swap for the 70? I don't know if the housings are the same.
I can fit a 3.5" DP with stock k if i plan it right. Does it have to retain A/C?
I havent seen the MPT76 yet.
