MAF being coated in oil - what are you guys doing to fix this?
Old 12-21-2005 | 08:15 PM
  #16
RICEFEDZ28's Avatar
Re: MAF being coated in oil - what are you guys doing to fix this?
Mine is on non preasure side and pcv is in stock location.
Old 12-21-2005 | 08:18 PM
  #17
DarkHorse's Avatar
I ended up moving my MAF to the non pressure side.
I still have blowby and i'm sure the rings and or lands are toast but I have no plans (ie money) on rebuilding at this time. I'm gonna concentrate on chassis and suspension, race as much as I can next year till it grenades and then rebuild.
Old 12-21-2005 | 08:23 PM
  #18
Flip94ta's Avatar
Mine is on the suck side too, its really hard to fit on the pressure side with the afercooler.
I think my old rings were toast for over 10,000 miles, a few of them were cracked, as well as the ring lands. I had alot of little pieces when I pulled the pistons out. You know the car still pulled very well with 6-7 psi and smoked rings. I was beating some pretty fast cars on the highway.
Old 12-21-2005 | 09:04 PM
  #19
DarkHorse's Avatar
I just ran those times in my sig - probably broken and all. I can't imagine if I had good sealing rings and forged pistons what I could run the boost up to.
I would like to run around 12lbs boost thru a 4l60e and a 12bolt and get 500 to the wheels. May need to port the heads but should be attainable from what i'm reading.
HectorM52
07-30-2017 11:46 AM
artic94
01-17-2015 11:19 AM
94Z28LS1toLT1
01-15-2015 07:18 PM
squarehead
11-21-2014 08:02 PM
Red97LT1
08-07-2002 05:45 PM
Quick Reply: MAF being coated in oil - what are you guys doing to fix this?
