MAF Relocation help
Old 11-28-2003 | 11:46 PM
TravisA's Avatar
MAF Relocation help
I relocated my MAF to the pressure side and i'm now having trouble keeping the Piping together where the MAF is. I've ran it like this for months but once i turned the boost up it began blowing apart.
So i'm needing some ideas on how to keep it together. At the moment i'm using Fernco Plumbing pieces to connect the 3" pipe to the MAF. I'm needing a single piece that goes from 3 to 3.5"?
Does gates or anyone make such a piece? Show me your setup.
Travis
Old 11-29-2003 | 05:10 AM
96 WS6's Avatar
Try those v band clamps. Seems to work for some. Otherwise you may need to weld a lip on for the clamp to grab.
Old 11-29-2003 | 11:50 AM
TravisA's Avatar
Yep the V-band clamps were gonna be next. Do you mean weld a lip on the MAF? Is the MAF 3.5"?
Travis
Old 11-29-2003 | 12:53 PM
96 WS6's Avatar
Yes F-Body MAF is 3.5, the B-Body MAF is 3". And I meant to weld a lip on the intake elbow but maybe on the MAF too. I don't know, as long as it doesn't hurt anything.
Old 11-30-2003 | 05:08 AM
LT1RX7's Avatar
why not just use a T-bolt clamp? It's a $5 piece and I would be suprised if any turbo car can blow these apart. These can be found at http://www.roadraceengineering.com/hoseandclamps.htm you can also find 3" to 3.5" silicon couplers there
Old 11-30-2003 | 03:04 PM
TravisA's Avatar
Thank You LT1RX7 thats exactly what i was looking for!
Travis
Old 12-01-2003 | 09:00 AM
95 Silver TA's Avatar
Here is what I did:
You will have to scroll half way down the page to see the pic and write up:
http://camaroz28.cardomain.com/memberpage/342629/3
I got my hoses and constant torque clamps from http://www.turbohoses.com/
Hope that helps,
Claude
Old 12-01-2003 | 05:21 PM
TravisA's Avatar
Originally posted by 95 Silver TA
Here is what I did:
Hope that helps,
Claude
Thanks Claude!
One Question when you ordered the clamps did you get 3"or 3 1/4" and for the MAF did you get 3 1/2 or 3 3/4. Just making sure you dont need a little bigger clamp to compensate for the extra rubber from the 3" to 3 1/2" transition hose.
Thanks again
Travis
Old 12-01-2003 | 08:29 PM
I got just 3inch clamps for the tubing and I think 3.5 for the maf (I cant remember but I think the guy from turbohoses told me that that 3 inch clamp has enough slack to fit over maf and still be torque/tighten down) You may want to call tubrohoses.com and ask just to be sure. The tubing that they sell is very thin but very strong so you really dont need to go bigger on the clamps. They fit Great! By the way BEFORE I did this mods, I was blowing off my maf tubes like twice a week, since I did it, I never blew off the tubes again. I think I did this mod in June of this year so its held up real nice
Hope that helps,
Claude
Old 12-03-2003 | 09:04 AM
94 NO TOP Z's Avatar
I welded a 3" to 3-1/2" "header reducer" to my 3" piping coming from the intercooler. Then just used the 3-1/2" hoses with regular clamps on each side of the MAF.
Double aught
10-02-2015 11:29 PM
marlar98
09-19-2015 07:53 AM
tommalcolm
09-11-2015 03:39 PM
sleeperZ96BT
09-10-2015 08:01 AM
damnyankee36
09-09-2015 07:06 PM
Quick Reply: MAF Relocation help
