Map higher than baro air pressure?
Old 10-29-2007 | 12:14 AM
mrmint69's Avatar
I have read and read and i always see where the baro air pressure should always be higher than the map. Is this true on the supercharged units? Its not much and always at high rpm wot runs but i get it some times. The reading are baro .96 on some runs and the map reaches 1.04 and on some the baro starts at .96 and goes to 1.04 and the map will be at 1.04 also.
Old 11-05-2007 | 12:08 AM
mrmint69's Avatar
Well i replaced the map, connector and the orange seal and now the baro never changes or has the map get higher. I would have tested them one at a time but i didn't want the corrosion from the old plug or map to contaminate the new parts. Problem solved for $65.
HectorM52
07-30-2017 11:46 AM
DirtyDaveW
12-01-2016 05:37 PM
Fatdog2
02-13-2015 08:19 PM
95chwagon
01-13-2015 09:19 PM
Quick Reply: Map higher than baro air pressure?
