Modification to FLX 220 fans for fitment?
Old 06-21-2009 | 12:38 AM
  #16
ak95ta's Avatar
Originally Posted by The SRZ
ak95ta, how exactly did you get it to mount to the radiator? Mine just came in yesterday and before I tear into it I noticed there isn't any mounting brackets for the fans except the 4 clunk plastic units that came w/ the fans. Those clearly don't seem like they'll work so I was just curious as to how you mounted yours. Did you position the fan so it sits on the lower radiator mount and how did you secure it if you went this route?
I couldn't get those 4 palstic units to work either. I went down to Schucks and got those long plastic mounts for like a aftermarket tranny cooler. They just slide through the fins and use a snugging washer. I used 6 of them and working good so far, with about 2k miles on them. I mounted them as far up on the radiator as I could, so there is about 3 inches down low that are not covered. Hope this helps.
Old 06-21-2009 | 11:26 AM
  #17
The SRZ's Avatar
Cool, I just thought it was me w/ those plastic mounts. I'll have to go to the local store and see what I can find. You wouldn't have any pics of yours by chance would you? I may go the route of metal zip ties if I can't find anything suitable. Thanks for the info!
Old 06-27-2009 | 08:18 AM
  #18
ford's Avatar
I have the same griffin radiator but have yet to buy my fans for the setup. Sre there any other choices that fit better to the griffin? i would rather not hack at my new fans.
Old 06-27-2009 | 12:39 PM
  #19
ak95ta's Avatar
The fans may work for your griffin radiator. The modification I did was for fitment with the stock radiator.
Old 06-27-2009 | 01:38 PM
  #20
94SLUG's Avatar
They will not work on a Griffin radiator and auto trans! Summit dual 11inch pullers fit perfect...
jerrysims71
08-15-2015 12:47 PM
4586
08-02-2015 01:45 PM
Devinfoote87
07-30-2015 09:54 AM
Catmaigne
07-14-2015 05:17 PM
Jmj93z28
07-08-2015 06:58 AM
Quick Reply: Modification to FLX 220 fans for fitment?
