More questions regarding Crankcase pressure?
#16
on my car i will be running a line from each of the valve covers to a catch can (possibly 2 line from each)
ill plug the pvc valve.
my car isnt a daily driver, more of a weekend car / street car, si ill probably check/drain the catchcan once a month (when i change the oil)
i didnt mean to sound snotty, i thought you were referring to the actual catch can, not the filtration.
#18
Kelly you weren't snotty. I understood you. It's just nerve wrecking trying to figure something out that works.
TA/KID what would you plug the PCV up w/? I know the vac line can just be capped off but what do you plug the pcv line up w/? Weld the port shut? I myself like some sort of filtration that's why I'm just using that setup.
#19
#20
There are two issues we face that have to be addressed with the PCV system.
1. Ventilation of the crankcase to keep harmfull moisture and blowby from getting trapped in your crankcase and causing premature wear.
2. Removal of pressure build up in the crankcase from blowby and high rpm's that causes leaky seals.
If you are simply running two -10 lines from the valve covers to the filtered catch can then you are not addressing issue #1. That system would work well for relieving pressure build up but will leave harmful contaminants in your crankcase and oil.
I would leave the stock PCV hose/valve in the drivers side intake manifold to get rid of all those contaminants when your in vacuum.
#21
-B
#22
Yes, that filtered catch can seems like a great idea for the breather tubes. I've tried breathers screwed directly in the valve covers and it makes an oily mess and smells bad. If the catch can was placed above the valve covers most of the oil would drain harmlessly back into the valve cover.
I would however not delete the PCV line. I would just put an air/oil separator in the pcv line that that goes to the manifold so you can reduce the amount of oil that gets sucked into the intake manifold.
#23
-B definitely keep the pcv in place and just use what 97WS6Pilot and everyone else on here has suggested w/ the oil/water seperator.
97WS6Pilot do you know how much oil you were blowing out the breathers? Not concerned w/ the oily smell but the oil all over the bay would get old I'd imagine.
#24
#25
Or would the morso kit that uses the exhaust as a vaccum on the valve covers be more efficient?
-B
#28
Now when you mention a filtered catch can to the breather tubes Im assuming you're talking about connecting the both valve covers via some braided line and into a catch can thats vented/filtered to the atmosphere?
-B
-B
#30
