More questions regarding Crankcase pressure?
Old 07-01-2007 | 03:44 PM
  #46
97WS6Pilot's Avatar
Originally Posted by ZBLKHELLRZR
If you are concerned w/ the blower sucking oil, why not use the seperator between the pcv instead of capping the end under the tb?
I'm using the oil/seperator and not running it to the blower as I didn't want the oil on there. See the 1st page of this thread to see what oil seperator I'm using. The VC I'm just using breathers (3) but decided to switch and run -10 off of each VC to a vented catch can. I can deal w/ the oil smell but not oil over the engine bay.
I think this is the best solution. Although I'm running a much cheaper oil/water separator and catch can. My catch can is an old can of beans that has a K&N filter on top and one 1/2 inch brass fitting screwed into the side. You can't really see the can because it sits behind the intake so I didn't spend any money to try to make it look good.
Old 07-07-2007 | 11:49 AM
  #47
blue's Avatar
There are two general choices:
---just vent the crankcase to atmosphere (no vacuum, almost).
This isn't the best for longevity because it doesn't clean corrosives out of the oil as much, but it is the easiest. This is all cars had until the early 60's.
---put vacuum on the crankcase
This is better but harder to do. To have vacuum on the crankcase under boost you have to either put lines from the valve covers to the low pressure side of the supercharger, to the exhaust, or to a vacuum pump.
Old 07-07-2007 | 11:54 AM
  #48
T/A KID's Avatar
Why not pull it from the PCV spot on the side of the intake with a 1 way check valve and a Oil/air seperator in between he PCV on the side of the intake and the suckside of the blower??
Old 07-07-2007 | 02:38 PM
  #49
blue's Avatar
You mean pull through the PCV port instead of through the valve covers? Yea, that would be just as well I guess. You would have to remove the PCV valve.
Old 07-07-2007 | 07:15 PM
  #50
T/A KID's Avatar
Yep thats what I mean, I plan on having a -10 welded onto the side of the intake and run braided line to the suckside of the blower.
I was just going to insert a checkvalve and a oil/air seperator with a Filter on it, and run it to the suckside of the blower.
Old 07-08-2007 | 05:41 AM
  #51
ZBLKHELLRZR's Avatar
Why would you have to remove the valve? Just trying to understand the reasoning behind it in what TA/Kid is trying to do. I'd think he'd definitely might see an increase in vacuum/better ring seal running it off the suck side of the blower too.
Old 07-08-2007 | 02:11 PM
  #52
blown383's Avatar
I believe someone above mentioned that when he did it this way the blower and the intercooler was completely covered with oil after a few hundred miles.
-B
Old 07-08-2007 | 10:24 PM
  #53
T/A KID's Avatar
probably didn't have a Good oil/air seperator in between. The person may not have had one at all?
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
linz
3rd Gen / L98 Engine Tech
10-22-2015 07:59 AM
Moshbmx1
02-17-2015 10:51 AM
07-04-2005 05:00 PM
Quick Reply: More questions regarding Crankcase pressure?
