Need Help Asap!!!!!!!
Ok ...need some help here please please but some info...I am doing an eng build up this winter for my SC 353/355
Goal will be to but down 600ish rwhp...not this coming year but next..Ineed to no what parts i NEED,what parts are a nice to have,not NEED,wast of money..I no a eng at this level is not cheap and i can live with that but ....i need top no what is the best for this combo....
-pistons- JE
-rod h beam 4340, L19 rod bolts
-4340 crank
-rigns?
-bearings?
-balance to 0g
-fly wheel/clutch to N
-front hub N do i need to do this with the ATI bb 2 key
-do i need to fill the block
-4 bolt set up witch one, do I or should i 4 bolt the front bearing
-stock oil pump or hv
is there anything i am miss please put it in .....
THX
-pistons- JE
-4340 crank
-rigns?
-bearings?
-balance to 0g
THX
Re: Need Help Asap!!!!!!!
TTT....
what 4 bolt set up are people doing...and is there a cost diff....
are the ring that come with the JE pistins good, i read some where to order the pistons with NOS rings...RK i think said this...
anyone
anyone
The JE pistons come with a nice set of moly rings that should be adequate for all but the most extreme uses. If you want to upgrade though, the "Hellfire" rings are very nice. PITA to gap though, they are pretty hard.
Rich
Rich
I ordered my rings from them with "boost" in mind ... they sent me the best they had.
Anyways... with the proper gap i think JE pistons will suffice... i did 607 with them @10psi boost... so they work.
The middle three should be sufficient. Oliver makes a nice set of billet main caps, they even stamp OLIVER into them. LOL Anyways, they're about $240 bucks or so for the three, then figure on another $100 for a main stud kit from ARP.
I don't think the block would really need to be filled unless you're turning some serious RPM or running alot of boost. If it's a street car, don't fill it all the way, just enough to strengthen the main webbing because it will run hot. If you do decide to fill it, it would be a very good idea to revamp the cooling system.
Henson071
09-21-2015 04:31 PM
